Results 1 to 10 of 21
Thread: filter/pump problems - pool newbie
    Pottstown PA
    Default filter/pump problems - pool newbie
    Hello,
    I moved into my house over the winter and I'm trying to get the pre-existing pool going. Before this I knew NOTHING about pools.
    My pool is 30x15 and an est 15k gallons. It's an above ground pool but it is somewhat in ground. It has a deep end and to me it seems like an in ground pool. I have a DE filter and a 1.5 hp pump. It seems the system is fairly old. The first time I plugged in the pump it spewed water out of the hose which connects the filter and pump. So I replaced that one and the pump worked but not much came out of the jet so I replaced all the hoses cause they seemed pretty leaky. The water at this point was pretty green. I got the filter going pretty good and actually had it going for several hours and then I read that you shouldn't run the filter without DE in it. Woops. So I put DE in and the pump pushes water but it doesn't seem like much. The pressure shoots up to 20psi but sometimes fluctuates up and down pretty rapidly (from 10 to 20 psi). It generally runs at 20psi. I thought that seemed high so I opened up the filter. The filter elements were covered with green crud, I'm assuming this was DE covered with algea. So I hosed them off thoroughly and put them back in and put DE in. It still runs about the same. The pressure goes up to ~20psi and the water flow isn't great.
    So my question is, could my filter elements be screwed up? I read you shouldn't run it for more than a min or two without DE and I ran it for several hours with a really dirty pool so it seems maybe I did. I'm pretty close to saying forget it and just going and getting a new system, a cartridge one as they seem to be the easiest to maintain. It seems that would be better than buying new filter elements for $35 each, especially since the pump/filter seem to be pretty old (man I wish I would've asked the seller for info about the pool!).
    thanks a lot,
    Ryan
    duraleigh Guest
    Default Re: filter/pump problems - pool newbie
    Hi, Ryan,
    It sounds like your issue is with algae....you've got to get that killed and out of your pool.
    If you could post test results for :
    Free Chlorine
    Combined Chloramines
    pH
    Alkalinity
    CYA
    That would help us all from guessing and we can get your pool cleared up. I am assuming from your description the pool has a vinyl liner. Is that correct?
    PS - If you get a new filter and ease of maintenance is your primary concern, get sand.
    Indiana.
    DE filters are so good at getting small stuff out of the water that they seem to require almost constant attention when fighting an algae problem. You may have to work on it every 15 or 20 minutes for a while. Get your chlorine level up and kill the algae or it will get worse.
    Honesdale PA
    Ryan,
    Welcome to the forum. The advice you've gotten so far is good. I just want to comment on your statement about cartridge filters being the easiest to maintain. In my opinion...a definite MAYBE. I have only ever had sand. I believe cartridges would have the same problems you're experiencing now with plugging during an algae bloom, and, they are expensive to replace and a pain to clean. The opinions about which type of filter is best has been discussed to great extents on these forums over the years. Unless you are a total clean freak, sand may be the best way to go. Cheap to maintain as there are no replacement parts unless damaged, and just backwash, rinse, then switch to filter and go. Cartridges and DE do filter smaller particles but a few of us have been adding a little DE to our sand filters to get the best of both worlds and it seems to work. So, bottom line, if you are considering changing out the equipment, do a lot of research here, post with questions, then make a very educated decision.
    There is no "best" filter system--all 3 can be very effective. There is a best for ME, CarlD--that's sand. My dad's best was DE. Other members LOVE their cartridges.
    There is a wrong filter--that's the one you HATE and wish you hadn't bought.
    Pottstown PA
    Thanks for the replies. Yes it is a vinyl liner. The pool at this point is not green, it's "blue". The water is pretty cloudy (I can't see the bottom even in the shallow end) but the green that was there is now gone. It's been that way ever since I had the water tested and put chemicals in (that's a whole other story/problem) which was about a week ago. So do you still think it is algea?
    I don't have the numbers but just using a test strip this is what I get:
    Chlorine is very low to low
    pH is low to ok (6.8-7.2)
    alkalinity is low to ok (40-80)
    Cyanuric Acid is low
    When I first went to the pool place and had the water tested all my numbers were way high but they had me put in too much and then all my numbers were way low! The last thing I put in was 10lbs of "soda ash". I've also put shock in multiple times (including this morning after doing the soda ash yesterday) and still no chlorine. I was looking at this as a separate issue than the filter/pump but maybe it's not?
    Is it not likely that my filter grids are screwed up from me running the pump for a while with potentially no DE in the filter? If I put too much DE would it cause this problem?
    That is interesting that you're saying cartridges are not as easy as sand. I definitely got the impressing cartidges were easier from what I've read on various sites. The concept of it seems easier to me for some reason.
    thanks again for the help
    Ryan
    Indiana.
    Quote Originally Posted by ryanm
    Until you have to clean them, cartridges are easier. With sand, to clean you turn a valve, let the pump run for a couple of minutes while sipping a drink, shut the pump off, turn a valve, let the pump run a minute or so while sipping a drink, shut the pump off, turn a valve, turn the pump on and go swimming. IMO, cartridges are the hardest type of filter to use and sand the easiest.
    Downingtown, PA
    Ryan,
    Keep the DE Filter bro! The reason the pressure keeps rising is because that 5 micron filtering ability is getting bogged down with that cloud of dead algea in the water. Just clean the filtering elements the best you can and then fire it up. Make sure your adding the DE through the skimmer and not directly into the DE filter before turning it on. Then wait for the pressure rise and repeat. Spend all day Saturday and by the end of it you should have a clean pool.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Sorry to just jump in here but I've followed this thread and I'm not clear why none of the more experienced here haven't addressed what I see as a pressing problem, that the filter was run for 'hours' without DE. This to me is a serious issue (tho not fatal).
    For backgound I run a Hayward EC-65 DE with a 3/4 hp SuperPump (and am very satisfied with it).
    If this were me, the first thing I would do is open it up and thoroughly clean, and then inspect the filter fabric. I don't think the warning to not run without DE is the risk of damage so much as that you will clog up the fabric with gunk that won't easliy backwash out. That fabric is supposed to provide the foundation of your DE coating, which will shed easily when backwashed, taking with it all the entrapped particulate. It's not meant to be the filter medium.
    That said, I think it would help if you posted the make and model of the filter so we could help you do this. IMHO, I don't think you're going to get optimum filtering/flowrate from it until you do, not to mention finding out why the thing is passing debris back to the pool. You'll also get a good understanding of how a DE filter works. In the case of the Hayward it's a very easy, straightforward process (tho a bit tedious with it's 15 nuts and bolts, God bless my B&D power screwdriver!).
    ChuckD
    Pottstown PA
    Hey Chuck,
    Ya know to me the running the filter without DE always seemed like a big issue since what I've read had warned against doing it for more than a couple of mins.
    BUT this is a non issue now as I said screw it and bought myself a brand new Hayward pump and sand filter. I can now see the bottom of my pool, woohoo! Still have some dirt/leaves in the bottom but hey I can at least see it now. All the rain we've had was actually good for me as I had to backwash so much the extra water was needed. Maybe I could of spent more time futzing with my filter but in the long run DE seemed like a pain in the ass anyway so I'm pretty happy with my purchase.
    thanks
    Ryan
