Results 1 to 10 of 21
Thread: filter/pump problems - pool newbie
Threaded View
  1. #2
    duraleigh Guest
    Default Re: filter/pump problems - pool newbie
    Hi, Ryan,
    It sounds like your issue is with algae....you've got to get that killed and out of your pool.
    If you could post test results for :
    Free Chlorine
    Combined Chloramines
    pH
    Alkalinity
    CYA
    That would help us all from guessing and we can get your pool cleared up. I am assuming from your description the pool has a vinyl liner. Is that correct?
    PS - If you get a new filter and ease of maintenance is your primary concern, get sand.
