Thread: bleach calc ??
    IL.
    Default Re: bleach calc ??
    The calc tells you how much to add to get to a certain ppm goal.
    Say you input your pool gallons (assuming you set the default so it's not metric, right? ) You test your CL, and you need to add 2 ppm of chlorine. Using the calc, you put in 2 ppm and the strength/% of the bleach you plan to use (like ultra clorox is 6%) and the calc will tell you how much you need to add to get 2 ppm in your pool.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    If it says (Gal.) under "Pool Size" then yes, it's gallons. If it says (L) then it's calculating in metric units and you'll need to go into the settings menu and change to imperial units. The Bleach Strength is the % of sodium hypochlorite in your bleach bottle (usually listed under ingredients or in the "warning" area of the label). Then you enter EITHER the PPM increase you're trying to obtain or the amount of bleach you've added. Then the calc with give you the OTHER calculation (the one you DIDN'T enter) when you hit the "calculate" button.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
