Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
Thread: Getting Calcium Levels Right
  1. #21
    Jul 2013
    Northern Illinois
    Default Re: Getting Calcium Levels Right
    Woot!!!! I can't tell too much from the video, other than I don't see bubbles?! Awesome! How are your plans for CYA and CH doing?
  2. #22
    Aug 2014
    Chelsea AL
    You're right... no bubbles! It started raining really hard here today so I'm waiting a couple more days to test the water again.
  3. #23
    Jul 2013
    Northern Illinois
    No worries. You have to wait to test that CYA anyway. Can you test your pH ASAP, though? It was high before...
  4. #24
    Aug 2014
    Chelsea AL
    I'm running it high on purpose. I'm hoping that the high acidity will help prevent the buildup issue. I'll lower it when pool season arrived
  5. #25
    Virginia
    Doesn't high pH encourage scaling?
    When you say "high acidity", you mean high pH, right? High acidity would be low pH.
  6. #26
    Aug 2014
    Chelsea AL
    I'm probably totally confused as to how Ph relates to the amount of acid in the pool. I want more than normal amounts of acid. Is that lower Ph? I thought it was higher Ph. :-(
  7. #27
    Virginia
    The lower the pH, the more acidic the water becomes. The higher the pH, the more alkaline it becomes. pH of 7 is neutral.
    https://simple.m.wikipedia.org/wiki/PH
  8. #28
    Jul 2013
    Northern Illinois
    Great posts, JimK!!!! jmarcum, don't go lower than 7.2.
  9. #29
    Virginia
    Quote Originally Posted by FormerBromineUser View Post
    +1!
  10. #30
    Jul 2013
    Northern Illinois
    So, jmarcum, did you lower that pH? Don't feel bad. We all have been there!
  1. Calcium Hardness Levels for Heater
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 06-01-2015, 08:25 AM
  2. Cloudy water in pool with high calcium levels
    By elocicero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2013, 12:39 AM
  3. Pool Calcium levels
    By beachfrontpool in forum Dealing with Alkalinity and Calcium
    Last Post: 08-22-2012, 12:39 PM
  4. Higher Calcium Levels & Stable pH
    By chem geek in forum The China Shop
    Last Post: 08-03-2008, 08:58 PM
  5. Low calcium levels, plasticizers in vinyl liners, leaching cobalt from fibergalss?
    By waterbear in forum Dealing with Alkalinity and Calcium
    Last Post: 04-21-2006, 09:07 PM
