Great posts, guys!
Yea, just try inputing different numbers. Like: if I raise my pH, my new CSI is ___. If I raise CH, and raise/lower pH, my CSI is ___. Play with the numbers until something makes sense for your pool.
Edit to above: I noticed on your screen shot that you had several variables that you were adjusting. To experiment with CSI, keep your values the same for both current and target. Only change the target on one, maybe two parameters at a time. These are the parameters that matter: pH, TA, CH, CYA, Temp, and includes any Borates and Salt.
The easiest thing to change is PH because it is a one for one change. Increase PH by 0.5 increases CSI by 0.5. TA and CH changes have less impact.
Mark
36'x20' Freeform, IG - 13k gal, Spa - 800 gal, Diamond Brite, Intelliflo VS pump, TR-140C sand filter, Mastertemp 400k BTU heater, 2HP Whisperflo pump (waterfall), Pool Pilot Digital RC-42 SWCG, K-2006 Test Kit
I didn't notice that either, though I don't pay close attention to CSI since I have a vinyl lined pool.
