Results 1 to 8 of 8
Thread: Cheap Cl? Check with your local pool store.
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Cool Cheap Cl? Check with your local pool store.
    I'm now buying my Cl from a neighborhood pool store. 2.5 and 5 gal. jugs of 12.5% @ $2.00/gal. They're asking for a $6.00 deposit on each bottle and I just bring 'em back for refills. New skids of Cl brought in each week so it's pretty fresh.
    I'm also looking at 36 empty Chlorox bottles on a rope out in my shed wondering 'what was I thinking?'.
    Anybody need some boat buoys?
    C.
    Edit: Oops, meant to say 10.5%
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Cheap Cl? Check with your local pool store.
    I've looked into liquid chlorine from local pool stores...unfortunately I've called EVERY pool store in a 30 mile radius, and NONE of them carry liquid chlorine.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    cajunfla is offline ** No working email address ** Thread Analyst cajunfla 0
    Jacksonville, Florida, USA.
    I bought some 10.5% chlorine today at the local "L" pool supply store. $3.95 after tax for 2.5 gallons. Comes out to $1.58 a gal. not a bad price, and saves me time from driving all around trying to find cheap chlorine at the other stores: Dollar General, grocery, hardware, etc.
    graciec is offline Registered+ Thread Analyst graciec 0
    I checked that L palce online and I didn't see any liquid.
    My closest pool store has 4 big (or whatever size oz.)gallons for 14$ or so 12%..still like to find cheaper.
    Does the L store [or maybe it's just a brand name]
    'Chlor- Brite' good or does it have CYA too.It says it's PH nuetral and can that go in a inline feeder?????.I would use it just to keep a little chlorine going in feeder but quit buying the borax,so it be worth it if it cost a little more.
    Fairfield, CT, US.
    My local Shaws has 1 dollar each for clorox 96 oz fri, sat, and sunday. That sounds pretty good (limit 10)
    Talking Re: Cheap Cl? Check with your local pool store.
    Yes,that helps. I am always looking for something easier than plastic jugs. Why can't the chemical companies make plain granular chlorine with no additives? I saw an ad for a british company that had tablets that you dissolved and made just pure chlorine.Are you listening pool chemical companies!????
  1. Green pool, advice from local pool store?
    By Darrenmv in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-09-2012, 01:25 PM
  2. Is a Cheap Pool a Bad Idea?
    By BigDave in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 12:09 AM
  3. percentage of hydrochloric acid, hardware store vs. pool store
    By dhanger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 02:45 PM
  4. Local janitorial supply store - 55 gal drum of 12% for $150
    By fishandfly in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2008, 09:50 AM
