Results 1 to 8 of 8
Thread: Cheap Cl? Check with your local pool store.
    graciec is offline Registered+ Thread Analyst graciec 0
    Talking Re: Cheap Cl? Check with your local pool store.
    Yes,that helps. I am always looking for something easier than plastic jugs. Why can't the chemical companies make plain granular chlorine with no additives? I saw an ad for a british company that had tablets that you dissolved and made just pure chlorine.Are you listening pool chemical companies!????
    Rehoboth, MA
    Default Re: Cheap Cl? Check with your local pool store.
    The problem is that pure chlorine is a gas and very dangerous. It has to be bonded with something else to get it into a safer form. The "something else" is usually something you don't want in your pool. In the case of bleach, the "something else" is sodium which is probably the least troublesome option of what's out there. The tablets you saw have to have something else in them besides chlorine. Try to find an MSDS sheet on them and that will tell the story.
    Peter
    Will have to tolerate the plastic for now!!
