Thread: Inground Vinyl Line Replacement Manufacturers Recommendations BBB
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default Inground Vinyl Line Replacement Manufacturers Recommendations BBB
    Pool is 30 years old and inground and use the BBB method of treatment. At age 67 this might be my last liner replacement as even now the existing liner other than showing wear and wrinkles still does not leak . But thought time to replace. Will use a pool company and the one uses Garrett Liners and the other Merlin. Looking for experience with both . I quickly did a search and saw some issues with Garrett on warranties and also fading . Any input appreciated or even another?
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    Jul 2013
    Northern Illinois
    Default Re: Inground Vinyl Line Replacement Manufacturers Recommendations BBB
    I don't really know about the different companies. Are you installing it yourself? If not, the installer might have recommendations.
