Thread: Do these work well together?
    Default Do these work well together?
    I'm sooooooo sorry for all of these questions, but I bet this one will be easy for you pros out there. Our pool is 15x30x52" and I think it's about 12,000 gallons of water. Here is our pump and filter info, and I'm wondering if I need to upgrade either of these: (they both seem fairly new)
    Filter is a PacFab Star DE ST-50. The "05" is punched out so I assume it's a 2005 model? Also, the "F" is punched out if that means anything. It says the design flow is 50, 4lbs. of earth required and a maximum working pressure of 50.
    Pump is a Dynamo 1.0 HP, 115 volt, 12 amp.
    We also have a Perform Max Pool Sanitizer (910 in-line).
    Are we good????
    Default Re: Do these work well together?
    That sounds very good to me. Not so sure about the pool sanitizer. I am sure some one else can add a little more on that.
    I do have hundreds of assorted bottom rails around the place. Next time you are in Arizona bring yours by and I will try to match it up.
    Later, Dennis
    WOOOOOHOOOOOOO! Something goes right! I could do jumping jacks right now (on second thought.........LOL).
    Oh boy.....I wish I lived near Arizona sooooooo bad! I'd love to get our pool up this weekend. Looks like we'll have to wait until next weekend though (which will probably be cold/windy/rainy). LOL! It's par for the course though in Ohio. 90 degrees one day, 50 the next. sheesh.
  1. Will this work?
    By HOF-City in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-15-2012, 08:41 AM
  2. I am at work and need help...
    By beaming90 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2010, 02:20 PM
  3. solarchlor does it work ?
    By dp_vegas in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-21-2007, 11:06 PM
  4. does it work??
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 02-27-2007, 08:32 PM
