Start Up After Re-Plaster - Lessons Learned?
Recently, my 30 year old, 18x36 plaster pool received a major overhaul. The coping, tile, and plaster were all redone. I opted not to have water trucked in so my refill took a little longer than the recommended 24 hours. The fill water ran constantly for about 36 hours and so far I have not seen any cracks towards the waterline. Currently, I am on day 3 of the start up procedure which involves:
- running the pump and filter constantly for the next 2 weeks, then 12 hours a day thereafter;
- brushing the walls and surface twice a day;
- testing the water daily;
- add muriatic acid as needed to keep the pH at or below 7.0 for the first 5 days;
- monitoring alkalinity and hardness, but not too concerned at this point while I am still filtering out plaster dust unless the hardness goes below 100 ppm; and
- broadcasted a metal sequestering agent.
I am looking forward to day 5 so I can begin to add bleach. I am paranoid with the water being bleachless at this point. Also, I know not to use an automatic vacuum for 2-3 weeks. It will be tough to just stare at the pool as I realize I can't swim in it for around 30 days.
Googling returns similar directions as I am following; however, has anyone tried anything different during the 30 day start up period? For those who have experienced a start up after re-plaster, do you have any lessons learned to share?
American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
