Results 1 to 10 of 28
Thread: clorox performance bleach
    Jun 2014
    West-Central Pennsylvania
    Thumbs up Re: clorox performance bleach
    Quote Originally Posted by MikeM View Post
    I saw this for the first time in my local Walmart today. It was $2.50, which is a great price. I generally use Walmart bleach, which is 8.25% in a 121 oz bottle for $2.94. That works out to be $0.29 per oz of chlorine. That's quite a bit better than my pool store, which sells 12.5% in a 128 oz bottle for $6.25. That's $0.39 per oz.
    Today, I noticed that my local Walmart had liquid chlorine for pools in the garden section, with their other pool chems. Per the label, it's 10.0% sodium hypochlorite in a 128 oz bottle for $2.50. That's just under $0.20 per oz of chlorine. Best price I've ever seen. I bought 6 gallons, but haven't tried it yet, so don't know the actual effectiveness. Just wondering if anyone else has used this stuff and would share their experience?
    I can also confirm finding Pool Essentials Chlorinating Liquid @10% Sodium hypochorite for $2.50/gallon at my local Walmart (Central PA area, Altoona). I don't even know what took me into the pool section, as I was only there for Great Value Bleach, but after finding it, I promptly took back all 6 gallons of GV Bleach @ 2.94/gallon and replaced with the 10% stuff.
    This seems like the best deal I can find on chlorine. None of the local pool stores sells the liquid stuff so getting a reusable carboy is not an option. I wonder if this stuff is accurately labeled, wanted to test it to see if indeed it's 10% as advertised, but didn't get the time yet. I also wonder if this is something new they just decided to get, or the fact that their shelves were usually empty of bleach each summer made them wise up and start carrying what the customers want?
    14'x28' rectangle 10.9K gal IG vinyl pool; 3/4HP Hayward SP2605X7 pump & S210t sand filter; (Laars Lite 2 LG 175) disconnected; Well H2O; Taylor K2006 kit. PF=11
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: clorox performance bleach
    Interestingly, I posted earlier in this thread my local Walmart didn't carry the Pool Essentials stuff, but my wife decided to check this week and there it is, newly stocked! I haven't checked to see the date stamp on it yet.
    Jun 2014
    I just looked at the date code on my bottle last night. 16 118, or April 28th normally, April 27th this year because of Leap year! So my stuff is roughly a month old.
    I don't think it matters much in my case and so far seems to be working just fine with my test numbers showing results. I need to find time to test the potency and see if its running true to 10%. Either way I doubt it would be significantly lower than 10%, or lower than the Great Value 8.25% Bleach I'd been buying for $2.94/gal which still leaves me in the good since it's only $2.50/gal.
    Jul 2013
    Northern Illinois
    A month is fine. They usually start over % so you're likely close to stated strength.
    May 2014
    I checked last night and the time stamp was 16 124. Love this forum, wouldn't have found that if someone didn't bring it up here. At 2.50 a gallon for 10% strength, that's the cheapest I can by chlorine locally.
