Cut your replacement pipe about 1/8" shorter than the pipe your cut out. Use a SLOW set pvc cement. Apply liberally onto all pipes and slip fitting couplers. Place couplers on both ends of replacement pipe and slip into place and then move couplers to the desired spots. The trick is the slow set pvc. Hardens in minutes instead of seconds. I am no professional. But this technique has worked for me.Originally Posted by waste
