ValAZ, posted below is the response I tried to send you to a private message you sent me.
Just had my IG pool done a week ago, and there's a leak in one of the return lines.
First question: do you know of any reason why a shotcrete sub would need to cut the caps off of the lines which are under pressure? Mine did - and now that I've got this leak, I suspect they did to cover up that they punctured or cracked a line.
Second question: I am concerned about running the pump and water getting behind the tiles and down into the plaster, which is 7 days old. Would this cause damage? I am not running it, and it is going to be 4 - 7 days before I get all of this fixed. In the meantime, I am brushing the pool even though it's not getting filtered.
Valerie[/QUOTE]
Valerie, I'm never too busy to help the members of the poolforum - it's the least I can do as repayment for all that I've learned. Unfortunately, I have zero experience with the 'cut the pipes after the shell is shot' school of plumbing which is why I didn't coment when I saw your post on the forum. I see you plan on doing a little digging this weekend - a good idea because whoever fixes the leak will probably be charging you 'time and materials' and the digging will take the most time. If you discover the source of the leak and think you might want to tackle it yourself, I and others from the forum will gladly walk you through the process.
As for running ther filter, I think you're best off not running until the leak is fixed, lest you etch the new plaster (it needs to be kept wet, but doesn't like direct pressure while it's curing). Keep up with the brushing, unfortunately you can't filter out the liberated 'stuff'. As an idea, I don't know how feasable it would be for you, some pool service companies (and hotels with pools) have portable vacuums (pump and filter on a hand truck)- might it be possible to get a service company out to do one vacuuming with one of these(or rent a hotel's unit for the afternoon)? - Just a thought![]()
Anyway, thanks for the confidence in me - sorry I couldn't live up to it ;(
- Ted A/K/A: Waste
