Thread: First Test Results
    Default First Test Results
    I just received my test kit and here are my numbers. I have a 35K gallon in ground vinyl pool with salt generator.
    TC 5ppm
    TA 180
    pH 7.2
    CYA 30
    Salt 3400ppm
    Temp 86 F
    Please suggest changes.
    How do you lower TA without lowering pH.
    Default Re: First Test Results
    read this post
    http://www.poolforum.com/pf2/showthread.php?t=191
    It gives you the step by step procedure for lowering your TA
  1. More Test Results!
    By mkfmedic in forum DPD-FAS based testing
    Last Post: 09-12-2006, 02:15 PM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  4. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
