Results 1 to 10 of 10
Thread: Repair / Replace Pump
    Oct 2011
    Southern New Jersey
    Default Re: Repair / Replace Pump
    Thanks for the info. Got it working OK. It was just debris inhibiting the impeller rod. Opened the back plate, turned it with screwdriver. First turn was tight and it squealed. then turned free. Plugged in and worked fine. Running now - usually starts at 10 psi on pressure gauge, now starting at 5. Flow out of eyelet feels strong, maybe a pressure gauge issue. Thanks again!
    Steve Romo (6700g AG, Cartridge Filter)
    mas985's Avatar
    Pleasanton, CA
    Sounds like it could be bad bearings too. If you find it making more noise that normal and/or shutting off on it's own, start planing for a motor or pump replacement.
    Mark
    Jul 2013
    Northern Illinois
    As an aside, I am SO glad that you still check in, Mark! Your expertise is so valued.
    Virginia
    Quote Originally Posted by FormerBromineUser View Post
    +1!
    Oct 2011
    Southern New Jersey
    Tried my old pressure gauge as a test and it read 10 psi just like it always did to start (the reason I had replaced it at the beginning of last season was because the weather had made the plastic window very difficult to see thru.) My other pressure gauge was showing 5! I thought that was the issue since the water stream felt strong! Thanks again for the feedback!
    Jul 2013
    Northern Illinois
    One way to check your gauge is to turn off the pump. The gauge should go to zero.
