Results 1 to 10 of 10
Thread: Repair / Replace Pump
    Virginia
    Default Re: Repair / Replace Pump
    Quote Originally Posted by FormerBromineUser View Post
    As an aside, I am SO glad that you still check in, Mark! Your expertise is so valued.
    +1!
    Oct 2011
    Southern New Jersey
    Tried my old pressure gauge as a test and it read 10 psi just like it always did to start (the reason I had replaced it at the beginning of last season was because the weather had made the plastic window very difficult to see thru.) My other pressure gauge was showing 5! I thought that was the issue since the water stream felt strong! Thanks again for the feedback!
    Steve Romo (6700g AG, Cartridge Filter)
    Jul 2013
    Northern Illinois
    One way to check your gauge is to turn off the pump. The gauge should go to zero.
