Thread: How to stay underwater without scuba gear?
    Jun 2014
    Nashville
    Default How to stay underwater without scuba gear?
    Pool leak I believe caused by vacuum pulling out vinyl patches made some years ago by American Leak Company. I need to go down and re-patch back what the vac took out. How can I breath underwater for longer than I can without scuba gear. I know it is hard but anyone?
    18 x 36 Liner Pool. About 1975 built in ground
    22,000 gallon, Hayward/ Jacuzzi Sand Filter
    Aqua pure Salt Water Generator, Chlorine Tab Dispenser
    1Hp super Pump
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Default Re: How to stay underwater without scuba gear?
    how far down is the spot where you need to patch?
    I just puttied a light conduit in the deep end. I only had to go down about 4 feet so I kept going up and down each time I needed air.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Jul 2013
    Northern Illinois
    You have probably solved your issue by now, but just in case:
    We have never repaired a leak, (knock on wood), but when we need to check something out, we use weights in the pockets of shorts to stay down and use plastic tubing for breathing.
  1. Repairing Leak Underwater
    By MunkeyTX in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2014, 08:23 PM
  2. Patching underwater vinyl liner
    By ears2hear in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2012, 09:09 PM
  3. Having trouble with the plastic drive gear on Baracuda MX8 wearing out
    By POOLLEDS in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-13-2012, 08:48 PM
  4. Deer in Scuba Steve's pool
    By DJK555 in forum Pools, Pets and Creepy Critters
    Last Post: 09-28-2010, 06:19 PM
  5. Using Air Drill Underwater
    By aswetich in forum In-Ground Pool Construction and Repair
    Last Post: 08-26-2006, 06:57 PM
