Thread: First test results
    Default Re: First test results
    Quote Originally Posted by poolbee
    Pool builder finally came and added stabilizer. After running pump/filter 4 hours I did initial tests.
    FC 3
    CC 1
    pH 7.2
    Alk 110
    Cal 170
    Cya 48
    salt 3,200
    pool temp 80
    Since the Cya was just added , I am believing that it will rise some in the next few days? I was told not to clean the filter for 3 days so all the CYA is mixed in.
    A week is better.
    And the pH is on the low side. Should I wait until the Cya is completely dissolved before making any adjustsment? Or should I make any at all?
    I believe you have a SWG....the pH will go up on its own...dont touch it. You will be adding acid to keep it down soon enough. Try to keep it around where it is now
    Will the CC go to zero once the Cya is up to snuf?
    How many hours a day does the pump run? You might want to increase it a bit. this can help with CC when you have a SWG. You should find that running the CYA close to 80 ppm and the FC at about 3 ppm will keep the pool nicely with no CC. Remember that you are supershocking the pool water in the cell whenever it is genterating.
    I swam for the first time today and the water is quite salty. Will this diminish as the water level drops(splashing out) and we add more, or rain? I think I would prefer the salt closer to the 2500 level.
    Running a SWG at lower salt concentrations will shorten the cell life. Most manufacturers recommend about 3200 ppm, some even higher.
    At bit higher than recommended is better than a bit lower in terms of cell life. I run mine at about 3300-3400 ppm and really don't taste the salt.
    One other thing-was this an error on my part or is this supposed to happen? When testing the Cal, there was a precipitate the same color as the water, just darker, swirling around the test container.
    This is normal. The first reagent in this test causes the magnesium in the water to precipitate out as magnesium hydroxide so you can get an accurate calcium hardness reading. The purple specks you are seing in the water is the magnesium hydroxide. The color of the water should be a definite blue. If it is still purple then you have not reached endpoint on this test. Keep adding drops and swirling until you get no more color change on adding a drop and don't count that last drop.
    Any advise on the numbers is greatly appreciated.
    If you have a plaster pool you should bump up the calcium a bit but if those numbers are from your own testing I suspect that you did not carry the test out to completion. Keep your salt where it is and don't let it go much lower. The CC should go away once the CYA is dissolved and the system stabilizes. You can either bump up your pump run time or increase the cell output a bit to get some more FC in the water but I would wait until all the CYA is dissoved since you might find that the FC goes up a bit on it's own then.
