Thread: Bubbles in pump basket?
    Default Bubbles in pump basket?
    when I have my Jandy valve right in the middle splitting the skimmer and main drain inputs I get a lot of bubbles in the pump basket. If I close the main drain the bubbles will subside And clear right up. How would I go about troubleshooting and seeing if I have a problem with the main drain lines? Thanks for any input I can maintain a steady pressure in my DE filter but it doesn't stay totally clear when I have it half-and-half.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Bubbles in pump basket?
    What is the filter pressure for each valve setting? Skimmer only, MD only and Both
    Mark
    Pressure on my e 65 de filter with valve in middle is16psi.when just skimmer its15psi and just main drain its13psi.
    mas985's Avatar
    Pleasanton, CA
    When the valve is set at 100% skimmer, do the bubbles get worse?
    When at 100% skimmer, check the skimmer to see if it is sucking in air from a vortex.
    If so, it could be low water level or a stuck weir
    If not, it might be a leak in the line
    Mark
  1. Air bubbles in pump basket
    By FormerBromineUser in forum Pool Equipment & Operations
    Last Post: 09-17-2014, 12:18 AM
  2. Pump basket lid stuck
    By cmcq in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:25 PM
  3. air bubble in pump basket
    By mbar in forum Pool Equipment & Operations
    Last Post: 06-02-2008, 09:25 PM
  4. pump will only prime when basket it out
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-23-2006, 10:52 PM
