Re: Bubbles in pump basket?
Pressure on my e 65 de filter with valve in middle is16psi.when just skimmer its15psi and just main drain its13psi.
When the valve is set at 100% skimmer, do the bubbles get worse?
When at 100% skimmer, check the skimmer to see if it is sucking in air from a vortex.
If so, it could be low water level or a stuck weir
If not, it might be a leak in the line
