Results 1 to 10 of 10
Thread: How long did your cell last?
    Mar 2012
    Long Island, NY
    Default Re: How long did your cell last?
    Sorry I haven't gotten back sooner, but good news is the cell is working again. My FC went over 4 even though the light was flashing and supposedly it was working at a reduced rate. I finally went down to the local Leslies and had my salt level tested. They said 2100 while my aquarite said 2400ppm. So I added more salt. I've added at least 160lbs so far this past 10 days. I don't drain my pool for the winter and I didn't backwash the filter at the end of the season. I opened it up and cleaned it manually. So how am I losing so much salt without a leak? I know evaporation lowers the water level, but the amount of salt is suppose to stay the same except for when the water is splashed out. Also mas985 can you give me a link to the chlorine without CYA is corrosive info because the hayward tech I talked to this morning said it wasn't. He said it would just help keep the FC level up, but not effect the cell. When I did add CYA 2 years ago it was flakes and I just poured it around the pool like I did with the salt. I can't recall if it just got sucked in through the bottom drain or I vacuumed it up, but I remember seeing it clogged up in the strainer of the pump. At that moment I realized why you need to put it in a sock. �� What I meant by clogging of the filter was I would have to increase the RPMs on the pump to 1400 or more because the no flow light would come on and the auto prime wouldn't work so I had to switch the pump to 3 minute prime. I also found out from a hayward tech that I was putting too much DE in the filter after backwashing. He said only put in 75% since backwashing doesn't remove all of it. One weird thing that happen today was while looking at the instant salienty # I flipped the switch on or off and the salt level went to 0. I then turned it on again and the # went up to 700, then I did it again and it went up to 1500, then 2100, 2400, 2700 and finally to 2900. It's finally back to work and the PH & TA are right on target.
    20'x34' rectangle 17.9K gal IG vinyl liner over concrete wall pool; Goldline T-15 SWCG; Hayward 4280 DE filter; Hayward 3400 VSP pump; Taylor 2006C ; utility water ; Hydramatic pool cover ; PF:6.7
    mas985's Avatar
    Pleasanton, CA
    Just google: https://www.google.com/search?source...69i57.1071j0j9
    Chlorine is a strong oxidizer and if not buffered by CYA it can cause issues. Chem Geek had posted about this on several occasions. A quick search revealed this:
    It is well known that high chlorine levels (especially in indoor pools without CYA) are corrosive to metals and that high chloride levels accelerate stainless steel corrosion (see this post).
    Those are known mechanisms with the only issue being the rate of such corrosion in 3000 ppm salt pools. It has been proposed that stray currents may also be to blame, but no clear mechanism for that has yet been found and that would not explain corrosion of the metal parts in a pool cleaner, for example, since there is no current flow from the electrolysis in the salt cell possible in that case -- the metal is just exposed to salty, chlorinated water and is not electrically connected (and such corrosion in non-SWG pools is still in salty, chlorinated water, but with lower levels of salt). If the bonding wire and all metal components were to have a positive voltage applied to them, then there is no question that metal corrosion would be greatly accelerated.
    http://www.troublefreepool.com/threa...ll=1#post14022
    Here: http://www.poolforum.com/pf2/showthr...-to-salt-pools
    There are probably a few more in here: https://www.google.com/search?num=50....0.kC-aNC4-XGM
    As for your decreasing salt level, it is either a leak or splash out. You have to be losing water (other than evaporation) for the salt level to decrease.
    If your readings are changing a lot or the cell sometimes works or sometimes doesn't, it could be the solder joint issue:
    http://nocellpower.blogspot.com/
    Mark
    Mar 2012
    Long Island, NY
    Sorry I haven't come back sooner, just found this going through my old emails. I found out after my last post that the lost of salt was happening because of a leak in the main drain . So I shut that side of the return lines and I'm just using the skimmers. Thanks Mark for the links I'll try to read them all when I have time.
