Results 1 to 10 of 19
Thread: My water is still cloudy and I don't know what to do about it
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default My water is still cloudy and I don't know what to do about it
    In my last Thread about 2 weeks ago, I took my water from horrible green swamp water to mostly clear pool water. It went well. However.. There is still cloudiness in the pool water. Maybe I'm being far too picky about it? When you stand on the deck and look in, it's fine. But when you're in the pool with a mask on and you look across the 30-foot stretch of pool, there's a white cloudiness to it, and you can't see the other side. All of my chemistry is good. Chlorine is 5.5 PPM. PH is 7.3. Stabilizer is 70. I can't remember the alkalinity, but when I tested it a week ago I know it was within range. I have been running the filter 24/7 for two or three weeks. Whatever it is, the filter is not stopping it. Is there a solution?
    I'm kind of a freak about Clear water, I'm not above dumping and refilling this thing to achieve it. LOL.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: My water is still cloudy and I don't know what to do about it
    If there is a precipitate in your water, your sand filter won't filter it, as is. The precipitate could be caused by metal/s in your water, of which there may be many. I am hoping someone with more chemistry knowledge will come in and speak more to the cause of your cloudiness, but here are some things you can try now.
    1. Add some DE to you sand filter. This will improve your filter's ability to capture smaller particles, though that still probably won't be enough to stop the cloudiness. There are great instructions on this forum for how to do it, follow them to the letter.
    2. Add some polyquat algaecide, which is the only algaecide this forum recommends, generally. It also acts as a clarifier, clumping particles together into bigger particles, and then your DE laden sand filter might be able to grab them better. If the cloudiness is being caused by algae, the polyquat can help with that too.
    All that being said, if the cloudiness is due to metal precipitate, I am not sure any of the above will help. There is a procedure for using a sand filter to filter out calcium, but I do not know it, hopefully someone else will chime in.
    All that being said, again, if your numbers are good and you are swimming, and your water looks relatively good, why worry? I am a big fan of clear water, don't get me wrong. But let me ask you, why do you have a swimming pool? Is it to swim in it, or impress the neighbors? If it were me, I would try the above, and if that doesn't work, don't worry too much about it.
    Anonymous [GDPR] European in the UK Guest
    There is only so much sand can filter (20 microns + for the best sand) so when it gets hazy it can take a long time to clear. Using a clarifier like jolly jelly can help speed up the process of catching the very fine stuff. Looking at your signature a 2 hp pump onto what size filter? Reducing that pump down would save a fortune in electricity and would improve the filtration.
    Howell NJ
    It would seem your stabilizer is too high.. @ 70 your target chlorine level should be an 8 ppm.
    And your shock level should be 27.5 ppm.. You probably still have stuff in your pool and need to shock it and hold it there...
    But...
    The shock levels shown have equivalent disinfecting chlorine amounts (in a column) but at high CYA levels it may be impractical to use such high FC levels. A partial drain/refill to lower the CYA level is usually what is needed or one can shock at a lower level but will take longer to kill the algae.
    Meaning it may cost a small fortune to shock your pool.. Best to drain some water to get the CYA stabilizer down to the preferred level of 30..
    Do that and shock the pool and hold it there.
    Filter 24/7
    Pool should clear up...
    Also whats the alkalinity levels?
    And yes adding DE to a sand filter helps.. Hope you have a large sand filter with that 2 hp pump.. A good solution is a 2 speed pump.. Run on hi to vacuum and run on low to filter..
    I run my pump on low 16 hours a day and it usues less electric then on hi for 3-4 hours.
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
    Aug 2012
    Nebraska
    Sorry to take so long to reply.
    My pool is now very clear! Yay!
    And I'm pleased to report that I didn't spend a dime to do it, either.
    I tried an old trick I used a couple of years ago to get rust-red out of the high-iron water we have: Old towels in the bottom of the skimmer basket. They seem to filter out even the smallest of particles. I changed them out morning and evening, and after about 5 days, super clear water.
    Boom.
    Aug 2012
    Nebraska
    Oh, and yes: The 2 hp pump is overkill. But I got it free and no amount of abuse seems to kill it. If it ever dies, I'll get a 1 hp.
    Aug 2012
    Nebraska
    This is looking long-ways the 32 ft dimension, both taken with my cell phone. I still have a little ways to go, but hey, it's free and it's working.
    Before
    After
    May 2014
    Lookin good! Love the idea. May have to try that one myself someday. I am in the same boat with my pump. I live in a place with very cheap electricity (lots of hydroelectric dams around), so I don't feel much of a pinch with my pump.
    Jul 2013
    Northern Illinois
    Missed this thread. How is the pool looking now? Still good? A bag of cal-hypo in the skimmer can help too if there is still some iron.
    Aug 2012
    Nebraska
    The pool is now crystal clear. Every 48 hours that towel comes out of the skimmer box Pretty Brown. I don't exactly understand why the towel works so well, but it definitely does make a difference. And it's free. I will post a few photos later in the day.
