Thread: cya levels
    Mar 2012
    Tennessee
    Default Re: cya levels
    You most definitely will need to add more acid. It will most likely take 1/2-3/4 bottle to bring up to 50-60. As for the alkalinity, it is my understanding that with an above ground vinyl pool you don't have to worry to much about that since you are at 70. If it was me, after I got the CYA up I would shock with 8.25% or 10% bleach. Should clear up the cloudiness.
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    Jul 2013
    Northern Illinois
    What is your CYA goal? You mentioned a bottle.
    Did you add liquid CYA this time? If so, it will register quickly.
