Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 33
Thread: CC higher than FC
    May 2014
    Sussex, WI
    Default CC higher than FC
    Hi all, I opened my pool about two weeks ago and am having a hard time clearing up the water. It looks milky green and I suspect it has something to do with the chlorine levels. I just tested before this post with these results.
    FC = 1
    CC = 1.6
    TC = 2.6
    TA = 110
    CH = 150
    CYA = 50
    My last test on Tuesday had similar results with the exception that CH was at 100.
    I've never had a CC reading higher than the FC. I first thought my CH was too low, but at 150 it's the same as it was last year. Any help will be appreciated.
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: CC higher than FC
    Your CC is high because your chlorine in combining with something (algae, bacteria, organic stuff). You need to get your FC up to "shock" levels according to the best guess chart for your CYA level and keep it there until you are able to hold chlorine overnight. Use bleach, 8.25% strength from walmart will raise your FC up about 3 ppm or so? (Sorry, my bleach calculator on my computer doesn't seem to be working!)
    As far as your CH, for a vinyl pool you really don't need to worry about it, unless it is way too high, which your is not.
    The one number you didn't post is your pH. That's an important one too.
    May 2014
    Sussex, WI
    Ooops. forgot to list PH. It was at 7.2 at testing. Probably a little higher this morning. It makes sense now. There is a fair amount of organic debris in the pool that snuck under the cover. I've got 12.5% shock ($2.49 a gal at Menards) I've got the pool calculator bookmarked so I'll keep cleaning the pool and keep the FC up there until things clear.
    Thanks so much.
    Jul 2013
    Northern Illinois
    Your shock level is 15 for FC. Get it clear!
    Here is the link to the best guess chart:
    http://www.poolsolutions.com/gd/best...ine-chart.html
    Once you pass the overnight test, I would aim for an FC of 6. 3 is your absolute minimum. I would never let it get below 4.
    May 2014
    Sussex, WI
    Well there's nothing like heavy rains to mess up balancing the pool. My PH is out of whack this morning. The good news is my FC is 15, CC is .8. PH is high now, but I'll get that straightened out quickly. My last two passes with the pool cleaner brought up much less organic material. I'm making progress.
    Jul 2013
    Northern Illinois
    Are you using a 25ml sample for your FC/CC tests?
    May 2014
    Sussex, WI
    I've always used 25 ml for testing chlorine. I've only used the 10 ml for the calcium test.
    Jul 2013
    Northern Illinois
    That's fine. While you are at shock level, you might want to consider the 10ml. 30 drops vs 75 is a bunch, especially if you are testing a lot. Just a thought.
    Virginia
    Quote Originally Posted by FormerBromineUser View Post
    At high FC levels I've even used a 5ml sample (1 drop = 1ppm) to save reagent.
    For normal everyday testing I use a 10ml sample. I never use a 25ml sample for FC. IMO, unless you're running FC really low, the .5ppm resolution 10ml sample size offers is fine.
    May 2014
    Sussex, WI
    Being one of those people who has to have his checking acct balanced to the penny, I probably go overboard on wanting accurate tests. I took your advice today and went with 10ml samples
    That being said, I'm confused today. My water is still a cloudy light green. I'm not stirring up much organic material when I brush or run the pool cleaner.
    My readings look right to me. Am I being impatient???
    FC= 9
    CC=.5
    TA = 100 - 150. (my last 25ml test was 110)
    CH= 150
    PH = 7.0
    I'm assuming my CYA is still around 50
  1. Higher pressure with new heater
    By LearningCurve in forum Pool Equipment & Operations
    Last Post: 08-27-2014, 09:08 AM
  2. higher ph ?
    By airraid1999 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2011, 03:40 PM
  3. Chlorine Higher than 15ppm
    By CUTURHAIR in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 02:52 PM
  4. Bleach and higher PH
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2006, 07:18 PM
