Results 1 to 10 of 33
Thread: CC higher than FC
    Jul 2013
    Northern Illinois
    Default Re: CC higher than FC
    JimK is absolutely correct. I was just about to say the same thing! I'm glad your CC's are coming down.
    Can you raise FC to shock level more than once a day? The more you keep it at 15ppm, the faster it will go.
    Do you have a sand filter? You could try adding some DE to it. I can send you a link about how to do it if you're interested.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Agreed. Fighting algae without getting to shock levels is sort of like fighting a large house fire with a garden hose. You will put out some flames, but your house will still burn down. Bring in the big guns and put it out!
    May 2014
    Sussex, WI
    Quote Originally Posted by FormerBromineUser View Post
    I can add bleach in the morning before I leave for work and again when I get home. Obviously, I'll test each time. What does DE do for a sand filter? I'm always willing to learn something.
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    Virginia
    Quote Originally Posted by beaverplt View Post
    DE helps the sand filter out finer particles. You have to be careful that you don't add too much and clog the filter. I believe you add a little at a time until filter pressure goes up 1lb. Btw, I have no experience with sand filters. I've only ever had a DE filter.
    Does someone else here have the link to the DE procedure for sand filters?
    Jul 2013
    Northern Illinois
    Here are the step-by-step directions:
    http://www.poolforum.com/pf2/showthread.php/3742
    You can buy 25# of DE at Home Depot for about $20 and it will takes years to use it all up! Just make sure it is "diatomaceous earth" for pools. Pooltime is the brand that Home Depot carries.
    Virginia
    Thanks. I figured you would have it.
    May 2014
    I learned the hard way that you have to WAIT after adding DE to see how much the pressure will rise. Add a little bit, then wait 20 minutes to see if your need to add more. Last summer I stood there adding DE like a mad man until the pressure rose 1 lb, and then I came back that evening to find the filter completely clogged.
    May 2014
    Sussex, WI
    So I've gone a week keeping my FC above 20 and still have the milky green/brown water. It seems like I'm getting a lost of dead algae (light brown water) out when I backwash, so I'm not sure that the filter is the problem. But after giving it a week, I'm going to try the DE. I did find that my local Ace Hardware carries 12 lb boxes of it for about $12.
