Results 1 to 10 of 33
Thread: CC higher than FC
    Jul 2013
    Northern Illinois
    Default Re: CC higher than FC
    DE can help your filter out. Btw, how often were you testing and bumping the FC back up?
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    If the DE doesn't work, try adding a little bit of polyquat algaecide. Not only is it an algaecide, but it also acts like a clarifier, clumping smaller particles together, which are more likely to get stuck in your filter. You don't have to use much, I bought a bottle recommended on the Pool Solutions site 2 years ago, and I have used it twice, only putting in 5 ounces each time, and it cleared my pool overnight, and within a week crystal clear. It will drop the FC levels so you have to plan on that.
    May 2014
    Sussex, WI
    in the morning before work and at night trying for 12 hrs apart. It seems I'm adding shock more often at night than in the morning. Maybe due to sunshine? I haven't tested tonight yet, but it'll be interesting to see what 3 inches of rain did to the numbers.
    Update. Just tested FC, CC, and PH. PH stayed at 7.2, CC stayed at .5, but FC went from 20 down to 13.5 in the 24 hrs. (I didn't test this morning with the storms.
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    Jul 2013
    Northern Illinois
    Yup. That's UV that causes the difference. Maybe you can sneak in one more test and add as soon as you get home from work?
    May 2014
    Sussex, WI
    Got some DE into the pool this afternoon. Went exactly as described. Pressure went up one lb with the 1/3 cup. As an aside, it seems odd that the smallest amount I could buy is ten pounds, yet I only needed 1/3 cup. I'm thinking I'm set for a while. One other note, don't use your wife's nice measuring cups. They're not harmed, but you might be.
    Jul 2013
    Northern Illinois
    Hahaha! Yup, better get your own measuring cups!
    My dedicated pool maintenance supplies include a 2Q and a 1C plastic measuring cup, a toothbrush, a pot scrubber, a scotch sponge with delicate scouring pad, a plastic turkey baster, a roll of paper towels, a plastic long-handled spoon, and 2 buckets: one small, one large.
    You can include the box of DE in your will. It may last longer than you will! Cheap, though, and worth it.
    Virginia
    Lol!
  1. Higher pressure with new heater
    By LearningCurve in forum Pool Equipment & Operations
    Last Post: 08-27-2014, 09:08 AM
  2. higher ph ?
    By airraid1999 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2011, 03:40 PM
  3. Chlorine Higher than 15ppm
    By CUTURHAIR in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 02:52 PM
  4. Bleach and higher PH
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2006, 07:18 PM
