Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 75
Thread: Cloudy Please help
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Default Cloudy Please help
    I originally put this post in the wrong spot...sorry
    We have had issues in the past with metal in the water so when I opened the pool a week ago I proactively added Jacks Blue Stuff for metal and 32 oz. polyquot. I could see the bottom it was not green but had a clear film on walls, I put 2 tri chlor pucks in filter and ran 24/7, it became cloudy immediately so I added 2-4 bottles of bleach every night and blue clarifier. Now its a beautiful blue but I cannot see the deep end drain, yesterday I added 8 gallon bottles of liquid shock (sodium hypochlorite 12.5) and another polyquot 60, I still had a low FC level.
    So today here are my numbers . fc 2, tac 5 cya 0,ta 80, ph 7.0
    The pool store told me ...to add soda ash which i did today and a bag of leslies powder powder plus (calcium hydrochlorite 73%) and to add clarifier tomorrow I backwashed a few days ago, it wasn't green, no metal stains so far .
    how can i clear this pool, please help thanks
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    Jul 2013
    Northern Illinois
    Default Re: Cloudy Please help
    Can you test your CYA with a home testkit?
    Your chlorine is burning off with no CYA.
    May 2010
    New York
    Fc 6.0 cc 5 cya 0 ta 80 ph 7.3
    Jul 2013
    Northern Illinois
    I didn't phrase my question well. Sorry. What testkit are you using? It says 2000.
    Anyway, I would add about 4 lbs. of CYA. See where you are in a couple of days. If you think you may need to backwash within the next 48 hours, do that first.
    May 2010
    New York
    Taylor k- 2006 , I will get the CA in the morning , thanks. So no more shock for now?
    Jul 2013
    Northern Illinois
    Was your CYA test solution cloudy at all? Let us know.
    If it was, just add 3#. And no, don't add more chlorine until you drop down to 3ish until you get the CYA in there.
    Jul 2013
    Northern Illinois
    Also, don't waste any more money on algaecide. You only need it when you close your pool for the winter.
    May 2010
    New York
    The cya test was not cloudy at all, thank you!
    Jul 2013
    Northern Illinois
    Okay. Then that means your CYA is close to zero. Add the 4#. How is your FC now?
    May 2010
    New York
    I will do another reading now...
