Thread: Pump motor replacement has hot casing
    Jun 2011
    Louisville KY
    Question Pump motor replacement has hot casing
    2016 Memorial Day.
    Turned on the pump and hummmm - no rotation. Loosened the mounting bolts, flipped the switch and it came on. Reassembled.
    I let the pump run for two days circulating water to oxidize some nasty squirrel and salamander carcasses.
    Charged the filter and vacuumed. Pressure spiked to 40 pisg, so I back rinsed, flushed, wasted, back flushed, flipping the switch many times for each change in operation.
    Then the motor stopped coming on. Eventually I gave up. Next day it came on but would run for 10 seconds and trip the main.
    After going in the basement to set the breaker about 10 times I ruled the motor dead.
    Next day I switched the motor since I had a new Dayton motor in storage. All is good - but.
    The Dayton motor diameter is less than the AO Smith I replaced. There is a small space under the motor case.
    Dayton motor case is very hot to the touch. Too hot to hold for more than 1 second.
    Mechanically & electrically everything is good. AFAICT.
    Why is that case so hot?
    Looking for troubleshooting options.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    May 2014
    Plano, TX
    Default Re: Pump motor replacement has hot casing
    I assume you are qualified, since you replaced the motor. Since the new motor is smaller than the old one, I wonder if it has a lower duty cycle. Manufacturers fudge HP ratings by reducing the duty cycle. A 1 hp motor with a 25% duty cycle will be smaller and less expensive than a 1 hp 100% duty cycle motor. Poor connections and bad switches can cause low voltage, which in turn, can cause overheating. How old is your switch, do you have a separate timer? Have you repaired the wiring lately. Do you have a good multimeter?
    Jun 2011
    Louisville KY
    Hi Pappy and thanks for responding. I replaced the switch about 5 years ago, and the service replaced two years ago.
    I have checked all your points, plus everything in the paper that came with the motor.
    I guess I will have my electrician come by for a look see.
    I appreciate the input.
  1. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 04:56 PM
  2. In-ground cleaning system, pump motor replacement question
    By kluczenk in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-20-2013, 05:46 PM
  3. Northstar pump motor replacement
    By masksav in forum In-Ground Pool Construction and Repair
    Last Post: 04-01-2012, 06:13 PM
  4. Which Replacement Pump Motor???
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 07-07-2009, 05:21 PM
  5. Pump casing very hot
    By Pamsel in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 09:49 PM
