Results 1 to 10 of 12
Thread: Newbie needs help/advice
    Default Newbie needs help/advice
    Hi All
    so we're changing from "pool store supplies" to the BBB method
    Pool info- in ground concrete/plaster pool; 10,000 gals, in full sun (southern california)
    this mornings readings:
    FC - 0.4
    CC - 0 (no visible change)
    Ph - 7.2
    alk - 110
    any advice greatly appreciated, went out and bought borax and bleach today ready and willing to learn
    thanks
    Di
    Indiana.
    Default Re: Newbie needs help/advice
    You need to post CYA numbers for exact advice. For now, put about 3/4 gallon of bleach in the pool, slowly. Take about a minute to trickle it in. This should put your chlorine around 4ppm. When you find out your CYA level, that may be too low or just right, but it will keep it safe for now.
    Central FL
    Also, it's probably a good idea to get a Calcium Hardness reading since you have a concrete pool. The range to be in is 200-400ppm.
    Welcome to the forum. You'll learn a lot here.
    duraleigh Guest
    How does your water look?
    water looks fine, clear with light blueish tint
    Don't have the CYA or calcium testing kit yet
    stupid question alert: anywhere in particular I should put the bleach in the pool?
    told you I was new to this!!!
    thanks for the help!
    Di
    I just pour it in the skimmer with the pump on and leave it on for several hours.
    Or you can walk around the pool dribbling it in.
    Or you can pour it slowly into the return stream.
    But no matter what your CYA is, your FC at .4 is definitely too low. I would add a full gallon of bleach and get it up to 5.5 (about) for now.
    But get those other tests!
    Better still, get your own test kit and run the tests yourself.
    ok just been in the pool box and found some test strips (I know they prob aren't the best but its all I have right now)
    just took this:
    hardness = 1000
    FC = 0
    PH = 7.2
    Alk = 180
    CYA = 0
    Di
    Forgot to add we have a DE filter
    Di
    Quote Originally Posted by poolgal
    just took this:
    hardness = 1000
    FC = 0
    PH = 7.2
    Alk = 180
    CYA = 0
    Di
    I HOPE those numbers are wrong...in fact, I believe they are impossible and either you read the strip incorrectly, or the strip is tainted.
    Hardness(CH) should be 200-400ppm. Scaling can occur above 500ppm and partial draining and diluting is the only cure.
    But Alk is 180 and with CH at 1000, you should be getting clouds and clouds of calcium percipitating out.
    Alk also is too high for your pool--it should be 80-125. Again, scaling can occur.
    FC = 0 means you have NO chlorine and NO protection against algae and other contaminants.
    CYA=0 means your chlorine has no protection against UV breaking it down, often in as little as 15 minutes.
    I would IMMEDIATELY pour in 3 gallons of regular bleach, and get some CYA ASAP and add it--just enough to bring you to 30-50ppm, no more.
    If you have tri-chlor pucks, now is a good time to use them because they will constantly add chlorine AND CYA. But they will lower your pH, which, at 7.2 is a bit low. Still, start with the 3 gallons of bleach.
    For your situation, high Alk, low pH, no FC or CYA, I would either use pucks, or add bleach and CYA.
    But I would also aerate my water and keep aerating it. With pucks, that's all I'd do, just keep pH between 7.0 and 7.2 and Alk should come down.
    If you do NOT use pucks but use bleach, I'd still recommend aeration, but everytime pH rises above 7.2, add Muriatic Acid to bring it back to the 7.0-7.2 range.
    But mostly, I'd get a better test kit (you clearly already know this) and maybe have a pool store test the water in the mean time.
    If CH IS that high, I don't see any alternative to draining off 2/3 of your water and refilling.
    The 3 gallons of bleach should help right now and, with your pool, can't hurt anything.
    TEst strips test total hardness (calcium and magnesium) not calcium hardness. You need to test for calcium hardness. Depending on your water makeup it is possible to have a very high total hardness but have a much lower calcium hardness. Also the strips have very poor resolution (the numbers on the color chart scale jump from 250 to sometimes 400, if you have a GOOD brand of strip, and then to 1000 ppm with no readings inbetween!) and the hardness colors are difficult to read with any kind of accuracy since they are such close shades of blue and purple.
  1. Confused Newbie needs CYA advice
    By dognostrils in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-16-2012, 11:07 PM
  2. Bottom Drain - Newbie Needs Advice
    By windfix in forum Pool Equipment & Operations
    Last Post: 12-28-2006, 03:34 PM
  3. Newbie needing advice about buying
    By zebfam in forum Above-Ground Pool Construction & Repair
    Last Post: 08-14-2006, 08:24 AM
  4. Newbie needs advice....so confused
    By AndieP in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2006, 08:44 PM
  5. newbie in need of advice
    By gaineycruzin in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-03-2006, 12:12 AM
