You need to post CYA numbers for exact advice. For now, put about 3/4 gallon of bleach in the pool, slowly. Take about a minute to trickle it in. This should put your chlorine around 4ppm. When you find out your CYA level, that may be too low or just right, but it will keep it safe for now.
