Results 1 to 10 of 20
Thread: How can I tell if I have algae?
    Jun 2014
    Nebraska
    Default Re: How can I tell if I have algae?
    I'd never thought about trying to capture rain water to refill the pool--that's a great idea! I'm always thankful when rain water gets in there because that's less crappy well water I have to add. I've never heard of a metal trap but I googled it, and that looks like something that could really help me out. We had our water tested not long ago. I should look at that report and see exactly what's in the water that causes it to be so cloudy. Maybe the metal trap would help to alleviate that problem. Meanwhile, I still haven't gotten my PH down or my FC up high enough to be a shock level. I'm probably too conservative with the chemicals because I'm always afraid of adding too much. This morning the numbers were: PH=7.8, FC=26, CC=.5, CYA=120. I added more bleach and more muriatic acid. I'll test again this afternoon and just before dark.
    18'x54" round Doughboy pool; 1/2 HP compact pool pump; 12" sand filter; very hard well water; TFTest Kits TF-100
    Jun 2014
    Nebraska
    I'm not sure what finally worked, but after about 12 days of working on this, I now have crystal clear water! I vacuumed and scrubbed the pool walls with a brush daily. I broke down and bought an Aquabot robot vacuum to help me out. I added a very small amount of DE through the skimmer, and started using skimmer "socks." I've had the chlorine above 30 ppm for 4 or 5 days now, and I've been testing and adding bleach as needed 3 times a day. CYA is still at 120. I don't think I'm getting an accurate reading on the chlorine level at night because I've been adding more bleach in the evening, and then re-testing the chlorine level at dark, and I feel like the bleach isn't evenly mixed up into the water enough by that point. The pump just isn't big enough to really get things stirred up good within a couple of hours. Therefore, my chlorine level probably isn't accurate at night. Sometimes it seems pretty high, and then it has dropped considerably by morning, even though I don't think algae is the cause. I'm going to go back to testing the water twice a day (morning and at dark) and only add bleach in the morning so it has time to mix up before it's tested again that night. Then I'll see if the chlorine level holds for the overnight test. I'd like to let the chlorine level drop down to normal range by this weekend.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Glad to hear you pool is looking better. Keep it up! Your pump is probably fine, its the filter that is too small, but anything is manageable.
  1. Pool had a lot of algae and now finally balanced and algae gone but
    By phillipjko in forum Dealing with Algae & Slime
    Last Post: 08-02-2015, 12:34 AM
  2. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  5. Green algae? Mustard algae?
