Thread: Pool Pump Fried?????
    Northeast PA
    Default Re: Pool Pump Fried?????
    I would suggest seeing how much a new pump would cost vs getting the one you have fixed as a starting point. I'm stuck in the same boat but mines the filter unit and not the pump kicking the bucket.
    mas985's Avatar
    Pleasanton, CA
    It is probably the bearings. If you have bearing pullers/press, you can replace them or you get a new motor to put on the wet end.
    Mark
