K. You may only find liquid at Leslie's. google your big box stores just in case. If you do go to Leslie's, DO NOT take a water sample in! If you go liquid CYA, add about 75 ounces. (1-1/2G).
thank you for the help! I will post new readings tomorrow !!! i am hopeful now....
16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
We gotcha covered! Night.
I bought the dry cya because the liquid said monosodium cyranurate monohydrate 35percent and I wasnt sure about that, I added about half the 4 pound bucket mixed with water to the skimmer as per the directions, will add the rest tonight and retest the water tomorrow. thank you
Okay. Tomorrow we will "assume" your CYA is 30. So tomorrow, take your FC up to 12 and keep it there by testing and addi g 2-3 times a day. This chart shows that your shock level is about 12. http://www.poolsolutions.com/gd/best...e-chart.html#a
ok i will keep you posted, enjoy the weekend!
my cya is 30 this afternoon but my cc =4 fc=1.5 I bought 2 cases of liquid shock and I will add 2 gallons tonight
