Results 1 to 10 of 75
Thread: Cloudy Please help
    Jul 2013
    Northern Illinois
    Default Re: Cloudy Please help
    Twice a day minimum... Do you know about the overnight test?
    Let's talk more about metals later.
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Ill test it tonight and then again in the morning to see if it holds?
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    Jul 2013
    Northern Illinois
    You make your last addition of the night and then an hour later, test the FC. The reason for the second test is that additions may not hit exactly your goal and testing MOE. Then in the morning within a half-hour of sunrise, test FC and CC. If you lose 1ppm FC or less, your CC's are 0.5 or less, and your water is super clear, you pass and are done shocking. Some people keep the levels up and do an additional overnight test. Up to you.
    I am not sure you're there yet because you probably lost 3ppm last night, but if you don't mind getting up early, go for it!
    May 2010
    New York
    ok I will give it a try, is it ok to add a sequestering agent
    Jul 2013
    Northern Illinois
    Jack's Ble is mostly for copper. The pink is more all-purpose.
    May 2010
    New York
    overnight test showed I lost 3, FC was 10 at night so I added bleach and tested an hour later ,I added too much i guess... it was 15, then early morning showed it was 12, pool is clear CC .5
    I will do another overnight test tonight.
    steps are very brown and liner slightly discolored from metal, I will try adding Metal Magic ProTeam today , I can get it at a local store, it has worked in the past.The Jacks Stuff I can get from Amazon but it takes a few days.
    We are having an electric heater installed this week because he pool never gets above 76, so I am treating myself. Looking forward to a good summer!
    thanks !
    Jul 2013
    Northern Illinois
    Okay then. You know what to do! After you add the Metal Magic and pass your overnight test, you may want to try the towel method here: http://www.poolforum.com/pf2/showthr...about-it/page2
