Results 1 to 10 of 75
Thread: Cloudy Please help
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Default Re: Cloudy Please help
    overnight test showed I lost 3, FC was 10 at night so I added bleach and tested an hour later ,I added too much i guess... it was 15, then early morning showed it was 12, pool is clear CC .5
    I will do another overnight test tonight.
    steps are very brown and liner slightly discolored from metal, I will try adding Metal Magic ProTeam today , I can get it at a local store, it has worked in the past.The Jacks Stuff I can get from Amazon but it takes a few days.
    We are having an electric heater installed this week because he pool never gets above 76, so I am treating myself. Looking forward to a good summer!
    thanks !
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    Jul 2013
    Northern Illinois
    Okay then. You know what to do! After you add the Metal Magic and pass your overnight test, you may want to try the towel method here: http://www.poolforum.com/pf2/showthr...about-it/page2
    May 2010
    New York
    Yes that's amazing, I bought skimmer socks which work well also. I will keep you posted, thanks
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    How do you know its metal staining and not dead algae? When you have an algae problem, it would be normal for some brown to accumulate in the bottom as it dies from the high FC levels.
    May 2010
    New York
    it lifts with a vitiman c tablet
    Pool is clear and stains are gone today. thanks , i will keep trying to maintain it, I will post numbers later
    Jul 2013
    Northern Illinois
    If it lifts with vitamin C, it's iron. I'm glad the stains came up! The iron is now still in the pool, it's just suspended in the water.
    Once you pass that overnight test, you can try using some cal-hypo added directly to the skimmer as your chlorine source occasionally. It may help remove some of the suspended iron onto your filter and then it will backwash out. The towel trick will help too. You may find that doing those two things will reduce the iron in the water and allow you to use less sequestrant down the road unless your "utility" refill water is high in iron.
    May 2010
    New York
    good to know, I will get some today
