Results 1 to 10 of 16
Thread: Closed pool with Iron Stains + Pink Algae... Now What?
    Upstate, NY (Dutchess County)
    Question Closed pool with Iron Stains + Pink Algae... Now What?
    Last year I was fighting iron stains (yellowish stains that disappear when a vitamin c tablet is placed on them) and "pink algae" (actually bacteria?) when I ran out of time and closed the pool in early September. Now it's that time of the season again I need to deal with these problems.
    I am hoping that shocking the pool when I closed it and shocking it again along with vigilant brushing of the walls/floor once the cover is off will take care of the pink bacteria. However I have some concerns since I'll have to let the free Cl drop (or keep it low to start) to get the metal stains out.
    To get the metal stains out, I understand that one needs to lower the Cl and pH, add asorbic (vitamin C) or oxalic acid to the pool to remove the stain from the liner and suspend them in the water, apply a 2-3x dose of a metal sequestering agent (metal free?) to "gather them up" then slowly bring up the Cl and pH.
    Perhaps startup is the ideal time to do this since Cl and pH are likely to be low to begin with but I'm a bit worried that the pink bacteria may come back if I leave the Cl level low while I'm removing the iron stain..
    Oh... and to complicate matters a bit I plan to switch to the 3 Bs (Bleach, Borax, Baking powder) this year. So I'll need to adjust CYA prior to sanitizing with the bleach as well. So many steps I'm a bit overwhemed. Here's the order I think I'm going to approach this.
    day 1
    test water
    start up pump/filter (cover on) run continously
    adjust Alkalinity
    add polyquat
    add asorbix/oxalic acid
    day 2
    add metal free
    day 3
    backwash filter
    adjust pH
    adjust CYA
    put pump/filter on timer
    day 3~10
    adjust Cl up slowly
    keep eye on CYA
    day xx
    remove cover
    Anyone have suggestions for my approach?
    duraleigh Guest
    Default
    Hi, Lee,
    You have obviously thought long and hard about your process. I would interject that, once you start, test and post your numbers here on the forum daily. That gives everyone a definitive point to start and will result in the best advice from the forum along the way.
    I am assuming you cannot drain and refill. That would certainly be the most bulletproof way of getting your metal out. Do you have an idea as to how it got there? If you refill from the same source, you will eventually have to do this battle again.
    P.S. I, and others on this forum, are not big polyquat advocates. I've only used CL and have been successful to this point. I think I understand why you're using it but Ben seems to think it works much better as a preventative than a cure.....Pricey, too
    Dave S.
    Katy, TX
    Default
    I think the use of polyquat here is a good idea, especially when operating with lower Cl levels. It'll provide a bit of insurance for you. However, with you being upstate, it's prolly still kinda cool there, so you most likely won't have to worry about a bacterial/algae bloom. It should work out fine for you.
    Michael
    Default
    Quote Originally Posted by duraleigh
    Hi, Lee,
    Will do...
    Absolutely no idea... there's no metal/iron anywhere in the pump/filter system. In 2004 I was a rookie pool owner and I put a lot of poolstore junk into the pool but I do not recall iron content in anything I put in. The previous owner of the house put the pool in so I am not sure if iron wasn't a problem before I got involved.
    I fill with tap water (city water). I will test it and pot the results here as well as my pool water.
    Dave S.
    ~$15/quart at Home Depot and Kmart is the best price I've seen. I'll add some initially when I'm doing the iron removal procedure since the FC will be low.
    Default
    Also keep in mind that the CYA dissolves VERY slowly and can take up to a week or more to completely dissolve and reflect accurate test levels. Don't add more CYA or backwash your filter for at least 4-5 days. Remember that it's much easier to sneak up on your target CYA number than it is to overshoot it, because drain/refill is the only way you're gonna bring it back down...
    Caledon, Ontario, Canada.
    Default
    I think you better find a pool store that can test for iron and take 2 samples with you. One from the pool and one from your fill source.
    If the iron is coming from the fill source and there is a lot of it you may want to consider tanked in water or directing rainwater into the pool. Likely need and extra dose for bleach after each rainfall but a lot cheaper than tanked in water.
    Got a heater maybe ... with an iron heat exchanger ??? That could be rusting out.
    mbar's Avatar
    Ashland, PA
    Default
    Last year I closed my pool with iron stains. When I opened it they were gone. So I would see if they are gone first. Then I would kill the pink bacteria first if you still have it by overloading chlorine. Once you are sure that the pink algae is gone - then you can work on the iron stains - because you can't keep a high level of chlorine when you are battling iron stains. I would do the bacteria first before I worried about anything else. Once that is gone, then you can lower your chlorine, do the stain treatment, then balance the water. You should be good to go - if you open to no iron stains, you may just have to deal with the algae, if you do - make sure you put in metal free before you do anything else. Keep your filter running 24/7 till you are sure all is clear.
    Marie
    Default
    Quote Originally Posted by mbar
    Marie
    ??? I was going to do the exact opposite since the condition the pool is in presenty (sat for the winter with occasional algaecide and bleach) is IDEAL for getting the metal out. Low pH and low FC.
    Once I have the filter hooked up and running, I was going to treat it with Ascorbic or Oxalic Acid (Vitamin C or United Chemical Pool Stain Treat) then immediatedly with Metal Free. Once I hit it with a healthy dose of Metal free, I may modify my plan with some skimmer sticks. This way I the Chlorine forces the metal out of the water it'll stain the filter/plumbing.
    If I treat the Pink Bacteria first, I would have to drop the FC to remove the iron and that makes me very nervous. I plan to keep the FC up fairly high and shock 1x/week once I'm sure the metal stains are indeed gone until the weather is warm enough to swim.
    mbar's Avatar
    Ashland, PA
    Default
    I understand that the water is ready for stain treatments, but if you have to kill the bacteria by using very high levels of chlorine, the stains will return even if there are traces of metal in the water. You will then have to do the whole stain treatment again, which is costly and hard to return the water to balance. Therefore I still suggest killing the bacteria first. Pink algae is hard to kill, because it gets in the lines, and I had a friend who had it behind the light of her pool. She finally got rid of it by using high chlorine for at least a week. My experience with staining is to make sure the water is free of any algae, then either use something that removes chlorine, or in my case I just waited a little and when the chlorine was around 1 or 2, put the stain treatment in. It will take the chlorine away - it will use a little more of the treatment, but that's all. Once you put in the treatment, put the metal free in right away. It will not take long for the metal to come off the pool, but it will take a while for the metal to get out of the water. After a day I would put a chlorine puck in the basket so that the stain will come off in the filter. I would keep the filter running 24/7. I always dose with a second dose of the metal free, then I start to bring up the chlorine - using the puck in the basket, and using regular bleach too (not in the basket). It can take a while for the chlorine to stabalize, because the chlorine will get used up while it is getting rid of the metal in the water. It is also hard to keep the ph where it needs to be, because the stain treatment is very acidic. It is important while doing the stain treatment to keep the ph as close as you can to 7.2, not higher or lower, you will find it hard to get the water balanced right after a stain treatment for a while. When you see the water holding the chlorine, and holding the ph, then you have the metal out of the water. That is why I say to get rid of the bacteria first - because if you don't have the bacteria out, and then have to use high levels of chlorine and you get stains back, you will have to do the whole thing over again. I had this happen to me, so that is why I gave this advice. You know your pool better, and all pools are different - If you don't have much staining, then your way may be better for you.
    Northeast PA
    Default Marie... So essentially...
    Marie... You make some god points... So essentially once there is iron in the water it's darned near impossible to remove it completely enough to prevent staining ever again. So does this mean that even after I do all of this I should never "shock" my pool again? So am I basically doomed?
  1. Removal of Iron Stains in the Summer?
    By hdjii in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-22-2012, 11:39 AM
  2. Refilling with well water (iron stains)
    By blepore in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-05-2012, 09:07 PM
  3. Pink Algae and White Water Mold in Pool
    By pclstuff in forum Dealing with Algae & Slime
    Last Post: 06-07-2011, 05:26 PM
  4. Iron Stains
    By Phillbo in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 03-23-2011, 11:43 AM
  5. iron/copper stains
    By daisyfrometa in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-16-2010, 11:07 AM
