Results 1 to 10 of 16
Thread: Closed pool with Iron Stains + Pink Algae... Now What?
    maryetta is offline ** No working email address ** maryetta 0
    Unhappy Re: Closed pool with Iron Stains + Pink Algae... Now What?
    I'm not sure what pink algae is. Could it possibly cause pinkish stains from the waterline up to the pool deck. That is what I was greeted with when I took the winter cover off my pool.(30,000 gal vinyl lined IG)
    If it is pink algae, why was there no slimey stuff , just stains? Scrubbing and an enzyme cleaner had no effect.
    Please help if possible!!
    mbar's Avatar
    Ashland, PA
    Default Re: Closed pool with Iron Stains + Pink Algae... Now What?
    Pink algae does wipe off, so I don't know what it could be. Do you have any problem with orange dust that may have gotten under your cover and stained? You can tell if it is a mineral stain by rubbing some ph down, or a vitamin C tablet on it. If that takes it off then it is a metal stain. If it is algae then chlorine should kill it. Some things like leaf stains, and stains from vegetation take some time to lift off, but with the regular use of chlorine in your pool you should see it fade over time. Hope this helps.
    Northeast PA
    An FYI for iron stains...
    I had mystery iron stains cropping up last year, mainly on the steps and around the bottom of the liner, where the wall meets the floor. I treated and removed, but they are back upon opening this year.
    Due to a new leak (I let my husband scoop leaves--don't get me started), I removed the light fixture to check the gaskets for leakage. I could not believe the amount of rust inside the housing! I had my service guys over replacing the sand, and they mentioned that acidic conditions could cause the rust. Now, I am VERY careful about keeping well-stocked with Borax and Ph levels up. However, the man who sold us the house never was--I know this because we had to replace the liner that wrinkled ALL OVER because of the low Ph levels.
    Anyway, you might want to check that light, especially when there seems to be no other source of the metal stains.
