Impossible.Is there any chance the RPMs turned out by the pump are causing the impeller to spin faster than it is designed to work at? (wild guess)
I don't think that would cause the issue.What about the impeller wear, I've checked it out and made sure it is clean, is there some symptom I might be missing?
Sounds like an air leak but why it would be periodic if isn't a weir or water level, I do not know. Sometimes, suction side leaks will pool around the broken part of the pipe and so will appear to work for a while as the water is drawn back into the pipe but after than happens, it should just suck air.
