Thread: chlor brite?
    graciec is offline Registered+ Thread Analyst graciec 0
    Default chlor brite?
    by L's pool supply.What is it? is it the same better or worse than liquid? can it be used with liquid? it says it's ph nuetral....
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: chlor brite?
    http://www.lesliespool.com/jump.jsp?...D=8080&tabID=3
    Well, it's sodium di-chlor......plain ole granular chlorine. Pucks are tri-chlor. I wouldn't state a neutral pH is 6.5 - 7.0....for a pool that level is acidic. It also has CYA....another added ingredient.
    That said, this would be a terrific product for someone whose pH is high and has no CYA.
    Sure, it could be used in conjunction with bleach for the same reason noted above.
    Hope this helps.
    CaryB
    Yes it does.Just always looking for something easier than plastic jugs. Why can't they make plain chlorine granules??
    I saw an add for a british company that had plain chlorine tablets. Are you listen pool chemical companies????
    waterbear's Avatar
    St. Augustine, Fl
    They do make unstabilized chlorine granules...It's called calcium hypochlorite or cal hypo...it is slow dissoving in granular form and not slow enough in puck form so it's ususaly granular. It adds calcium every time you use it which might be good or bad depending on what your calcium, TA and pH are.
    So check calcium numbers and maybe it might work in a vinyl pool in a pinch? What is a good brand(s) with the least additives and most available CH?
    waterbear's Avatar
    St. Augustine, Fl
    Some people use cal hypo as their main sanitizer. It's biggest drawback is that you have to predissolve it and if any undissolved stuff hits the liner you have to brush until it dissolved or it can bleach the liner. Also if your TA is high it can cause cloudiness. Look for one that is about 65-68% active chlorine. Some of the ones out there are only abut 45% active chlorine so they put more 'junk' in your pool. Bleach and liquid poolstore chlorine (both are sodium hypochlorite) are ususally cheaper to use. There is another form of granular unstabilzied chlorine called lithium hypochlorate. It is the fastest dissolving, usually as it touches the water but it is only about 35% active chlorine and is the mo$t expen$ive chlorine you can buy! Other than pH it has very little impact on water chemisty just like sodium hypochlorite. Very few people use it because of the price. All of the above forms of chlorine can raise pH to one degree or another depending on which one you use so keep an eye on that and adjust with muriatic acid when necessary.
  1. Diamond Brite Start up procedure
    By cdocon in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2012, 09:15 AM
  2. Diamond Brite colors
    By eljefe281 in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2006, 04:16 PM
  3. How long til we can swim w/Diamond Brite?
    By 3boysmom in forum In-Ground Pool Construction and Repair
    Last Post: 07-17-2006, 01:46 PM
  4. Relining with Diamond Brite
    By PatL34 in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 10:33 AM
  5. Zeo - Brite/Best/Ultra ?? I'm so confused
    By Aranon in forum Pool Equipment & Operations
    Last Post: 05-28-2006, 01:24 PM
