Re: Just added pH up and pool got cloudy
Mr. Bill:
I KNOW it's tough to absorb everything. Sometimes, when the pool is cloudy and we are panicking, it's tough to remember that the MOST important thing is to keep our water sanitary.
IF your strips are accurate, a TC of 3 and an FC of 1 means you have a CC of 2--and that ain't good! It means you are fighting some kind of organic, probably algae about to start. If you don't fix that, other problems will seem minor. Since your CYA is 50 (according to the strip) your FC level should ALWAYS be between 3 and 6--preferably 5 or 6. Shock by raising chlorine to 15.
Fix that first--A pH of 7.0 is low but livable--and chlorine is more effective at lower pH levels. A pH of 7.6 is fine, too.
Once the chlorine is fixed and your pool is sanitary, you can concentrate on the other issues. Frequently, fixing the chlorine clears up other issues.
