Results 1 to 10 of 13
Thread: Can't stabilize ph
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Can't stabilize ph
    A few questions:
    1. What are you using to test your pool? Test strips, pool store, taylor kit?
    2. What does your pH normally sit at, what is it "rising" from?
    3. If using a Taylor or similar test kit, what are your other numbers? FC, CC, Alk?
    Pools using chlorine will generally not smell bleachy unless the pool is dirty or fighting something, or immediately after removing the cover. My pool has almost no chlorine smell, except after a day of lots of kids in the pool (there is no "P" on my ool). After I shock it the smell goes away.
    Jul 2014
    MI
    Hi thanks for responding. I'm using Taylor test kit. So far this year the pool don't smell bleachy. My numbers are ph 8.0 cl 6 alk 140. My ph is rising it seems whenever I add bleach. I'll add MA the cl within a couple days will drop then I'll need to add bleach then my ph is back up. It's a circle. What can I do to keep my ph stable when adding bleach?
    14k gal AG pool, 150 sq ft cart filter. PF=8
    Jul 2014
    MI
    The pool looks great just worried about ph being 8.0.
    May 2014
    Do you add anything else to the pool? How do you add chlorine? pH tends to go up with alk, so if your alk is high, your pH will want to be high. You could try dropping your alkalinity, some people get it down to 50-80 ppm.
    Jul 2014
    MI
    I haven't added anything else. I just add cl to the skimmer/pump and let it circulate. How do I decrease the alk? Do they make a ph stabilizer? Usually I use the bbb method but I don't know if this fits in the bbb method. Thanks.
    May 2010
    Hi cdingess,
    How are you testing pH? With Taylor's phenol red drop test?
    The CYA 80 ppm is a bit high, forcing you to maintain your pool with fairly high chlorine levels. Enough to produce a false high pH reading when using phenol tests.
    It would seem like the pH is rising whenever you add bleach but it's probably just that the chlorine has affected the pH test. You could test this proposition by waiting to test pH when total chlorine falls below 5 or 6 ppm. Or borrow someone's pH meter to verify.
    Or you could dilute your high-chlorine sample water sufficiently (with distilled water) to get a correct pH reading.
    I think Taylor warns about interference with the pH test at chlorine levels above 10 ppm but my own testing leads me to believe the dark purplish color that affects the test starts at lower levels (maybe 8 ppm FC?)
    "Do they make a ph stabilizer?"
    Yep. Except you're already using it... Sodium Bicarbonate is a buffer, as is Sodium Tetraborate. I'm not sure TA 140 is high enough that I would want to lower it through the recommended 'Lower the pH and aerate' routine. It's a hassle and takes forever (a few days).
    OTOH if your makeup water has much lower TA, it may be worth the time & effort to dump some pool water. This would lower your CYA, too.
    Lastly, I assume when you say "bleach" that you mean sodium hypochlorite (liquid chlorine 5 to 12%) from the grocery or pool/hardware store. If you're adding other compounds, they could contribute to higher pH (not trichlor, which would just escalate your already high CYA).
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
    Jul 2013
    Northern Illinois
    Virginia
    Quote Originally Posted by polyvue View Post
    Hi cdingess,
    My experience with the Taylor pH test kit has been the opposite from yours. As long as I take a reading immediately, I've gotten accurate readings with FC as high as the mid teens. The key being to take the reading immediately.
