Thread: Shaft Seal Leak Comes and Goes
    Oct 2011
    Southern New Jersey
    Default Re: Shaft Seal Leak Comes and Goes
    Thanks again swimdaddy. Hope Mark does chime in. But, while I can't open it up again for a few days, I went back over my pics of the various parts and got an idea. Although it seems the new seal is at fault, I realized I have not replaced any o rings on the pump. I wonder specifically about the pump housing o ring. It looked fine but when I placed the pump cover against it and screwed it on, I didn't feel any resistance from the rubber o ring. That's a tricky move anyway cause the o ring is not a complete circle. It has one area that angles down where the water flows upwards. I intend to replace that and the pump cover o ring next chance I get and take it from there. Still interested in any additional comments in the meantime. Thanks again!
    Steve Romo (6700g AG, Cartridge Filter)
    Oct 2011
    Southern New Jersey
    UPDATE: So I tried new o-rings but it still leaks from the bottom. Upon closer inspection I am certain that the leak is coming from the area of the motor flange. This means that water is definitely coming through the shaft. It is happening with both the NEW and the OLD seal sets. I have a total of 3 seal sets. My original (2010) has a visible chip on the ceramic ring. The second (2014) and brand new look identical and I can see NO flaws, yet they both leak badly. The rubber that surrounds the seals fits the impellar rod snugly, and all the housing looks OK. I am baffled!
    Oct 2011
    Southern New Jersey
    UPDATE #2... With leak getting worse despite new shaft seal AND o-rings, I decided to get a new pump. All good now. So now I am in autopsy-mode, trying to figure out what went wrong. If I can clean it up, I will at least have a backup pump. No visible flaws in shaft seal, impellar, housing, etc. yet water drips continuously from bottom (whether running or off.) Still interested in any suggestions. Curious if any of the following can damage a pump. 1. Often losing suction / pressure while vacuuming. 2. Using pump to run water thru garden hose for lowering water levels. 3. Holding water noodle over eyelet to squirt people. 4. Running pump (accidentally) with low water flow from skimmer. Thanks for the replies!
