Thread: chems good...bright green cloudy pool
    May 2011
    Reading, PA
    Unhappy chems good...bright green cloudy pool
    CYA - 50
    FC - 18 to 25 for last 2 days
    PH - 7.6
    ALK - 80
    cal - 90
    dead algie on the bottom but still a bright green.
    Put 2 gallons of splash free clorine, thanks to a stock person mixing it in w/the reg, 3 days ago. could that be part of my prob?
    This is the first time i have had algee i couldnt clear in a day or 2 ugg
    thanks
    In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: chems good...bright green cloudy pool
    Do you have a CC reading? I will share that for the last 2 years, no more than once during the swim season, I get a green pool but ALL my numbers look good, including CC, and I don't lose chlorine overnight. Unsure why. What has saved me is a little bit of polyquat algaecide, and overnight pool is clear.
    Jul 2013
    Northern Illinois
    Did you solve your issue?
    May 2011
    Reading, PA
    yes i did thx!
    Just must have been a stubborn strain. took a week and I did add the algicide which i usually only add to winterize. I also think weeks of 90+ degrees didn't help
    thx again!
