Results 1 to 10 of 12
Thread: Chlorine level
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Chlorine level
    My chlorine level is coming back at less than 0.5 ppm. The sample is pretty much clear after adding the OTO. And when using the Taylor kit with the DPD powder.. Does not turn pink.
    When I test the cyanuric acid it comes out to about 90-100. I just ran out of the cyanuric acid for testing, ordering more.
    The pool is clear, so far, but seeing some pink build up along the sides. Very little
    I want to catch this before it is out of control.
    Ph = 7.2. Alk = 60
    Is a AG 33 x 15 pool
    Should I shock?? Just worried about cysniric going higher.
    Using HTH pucks
    Any suggestions
    Barry
    Jul 2013
    Northern Illinois
    Default Re: Chlorine level
    Use straight liquid chlorine or bleach to bring you up to "shock" level according to the best-guess chart and keep it there until you can pass an overnight test. Make sense?
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
    Ok, so shock it tonight to bring Cl level up, that is what I thought...should I worry about Cyanuride level going up ??
    Would 90 appear to be a good level for stabilization
    Jul 2013
    Northern Illinois
    The pucks have given you a lot of CYA. 90 is very high. Your shock level is 20-22ppm FC. http://www.poolsolutions.com/gd/best...e-chart.html#a
    Use bleach or liquid chlorine rather than bagged shock as that will not raise your CYA level.
    Have you considered doing a partial drain and refill of the pool to lower your CYA?
    To be honest with you, I have not used the pucks that often this year, maybe twice a week, if that...I will use the liquid shock tonight, think I should switch to the granular HTH, I have some of that left ??
    With a week of 90 degree weather and sun all week, think that will lower my CYA ?
    Jul 2013
    Northern Illinois
    Your CYA will only lower significantly through dilution and occasionally over the winter.
    What is in the HTH granular? Is there cyanuric acid? Does it say Tri-Chlor or Di-Chlor? Both of those will raise your CYA higher.
    I am going to shock it tonight..The liuquid shock I have is Sodium hypochlorite 12.5%...will this raise my CYA level, or can I use it
    Jul 2013
    Northern Illinois
    That is perfect! That is liquid chlorine with NO CYA. Remember, you need to get the FC up to about 22ppm and keep it there by testing and adding until you pass the overnight test.
    Virginia
    Quote Originally Posted by FormerBromineUser View Post
    Agreed.
    Keep in mind I'm no expert, just a forum member who's been here awhile. Unfortunately the "experts" that use to post here haven't posted in a long time.
    It's important to keep FC at shock level until 3 criteria are met;
    1. Water is clear; no visible algae
    2. < .5 CC (combined chloramines)
    3. Overnight FC loss is 1ppm or less.
    As was stated, do not use anything that contains CYA, i.e. pucks, sticks, DiChlor, trichlor, etc. stick with plain bleach (no scents, no splashless varieties) or "liquid chlorine". Bleach and liquid chlorine (they are the same thing actually, just perhaps different concentrations) do not add CYA.
    Do consider a partial drain/refill to lower CYA. 90 is pretty high, requiring more FC to perform a proper shock. Unless you are using a SWCG, your CYA should probably be 30-50ppm.
    I hope this helps.
    22'x40' Grecian Lazy L 20K gal IG vinyl pool; Aqua Rite SWCG T15 cell; Hayward Pro Grid 6020 DE filter; Hayward Superpump 1hp pump; 12 hrs; Taylor K-2006; city; PF:6
    Ok tested my cyanuric acid again, and comes out to around 80.
    Tried to test for free chlorine with the Taylor kit and the water did not turn pink , just very light pink, but it turned pink the other day.
    When it turned pink the other day, I tested further with the sample for combined chlorine but did not turn pink again, so got no result for that, but like I said, did not really turn pink today, so I figured need chlorine.
    I did the cheap HTH test for chlorine (OTO), and got <0.5
    I am going to shock again tonight and add granular HTH, which is Calcium hypochlorite.
    The Ph was 7.4 and alk 80.
    I am still kind of in the dark with the whole CC, FC , TC
    I'll try to read a little about that tomorrow.
    Any suggestions/comments
    Barry
