Results 1 to 4 of 4
Thread: Skimmer Door
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Skimmer Door
    have a 33 x 15 AG pool.
    My problem is my skimmer door keeps getting stuck in the "closed" position.
    At first I thought maybe there was not enough water in the pool, causing less water to keep it from getting stuck.
    But, the level is probably an inch from the top of the skimmer, and when we were in the pool causing waves, it got stuck again.
    It seems to be in the right position, and lined up.
    Any suggestions
    Barry
    Jul 2013
    Northern Illinois
    Default Re: Skimmer Door
    If you have explored all other options involving water depth and stuff, you might need to sand down an edge. You might have had some settling causing a side to get jammed.
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
    One question I have had for a while...is the skimmer door suppose to swing in and out like a saloon door. Or is it suppose to get stopped from swinging into the pool side, by the frame.
    Virginia
    Mine gets stopped from swinging poolside by the frame.
    22'x40' Grecian Lazy L 20K gal IG vinyl pool; Aqua Rite SWCG T15 cell; Hayward Pro Grid 6020 DE filter; Hayward Superpump 1hp pump; 12 hrs; Taylor K-2006; city; PF:6
