Thread: Cloudy Water
    Jul 2013
    Northern Illinois
    Default Re: Cloudy Water
    Leave TA alone for now. I still think the cloudiness was from your CH add. (Assuming you don't have nascent algae). It is best to add calcium with low pH, like 7.2-ish. With your plaster pool, you want a CH at 250+.
    Also, remember you can use a 10ml water sample for FC/CC and multiply your drop count by 0.5, (or divide by 2), to save on reagents.
    May 2011
    Bakersfield, CA
    Ran pump all night. Tested FC this morning, it's sitting at 4 PPM. Cloudiness still is very present, I can't see a tangible decrease in the cloudiness. When I put the baking soda & calcium in the pool, I think they reacted together. Could that be? I don't know, I'm stumped.
    May 2011
    Bakersfield, CA
    Quote Originally Posted by FormerBromineUser View Post
    Should I add muriatic acid to lower the pH to 7.2 to remove the cloudiness from the calcium? Thoughts?
    Jul 2013
    Northern Illinois
    It will take time to clear the calcium cloudiness, but lowering pH will speed the process. Sorry that happened, but no worries, it will get better!
