My problem has been CYA. The level gets to 100+ pretty quick and then the chlorine doesn't work, then algae comes, drain the pool, buy more chemicals, etc
This is a viscioius cycle. What to do?
Use bleach, like we do.Originally Posted by Mr Bill
how fast does your CYA rise to 100 levels ? Have you been using the frog system for a while ? How often do you go through those chlorine packs ?
You can switch to bleach/liquid chlorine or use a combination of both. After you drain to lower CYA you may want to use a low setting on your frog to dispense trichlor as a steady supplement and use bleach for the rest.
I like the idea of having the feeder there to keep some chlorine going because at times I forget to add chlorine and that is a good way to get algae. The sun in socal really seems to use up chlorine fast so if you are not dilligent with adding bleach you could run into problems.
My CYA levels went from 30 ppm in April to 135 in about two months, but I was unknowingly using tri-chlor shock that was also contributing CYA.
I am switching over to non-stabilized shock (Na and Ca hypochlorite) but still want to use the FROG as you suggested. After draining my pool this week I cut the CYA in about half (50-60) with test strip. I ordered the Pool Solution kit on Tuesday and hope to closely monitor this in the future!
