Results 1 to 10 of 18
Thread: Best Shock for Algae
    Jul 2013
    Oklahoma
    Default Re: Best Shock for Algae
    Well, I doubted my little Wal-Mart was going to have the HTH kit but they did!
    I have run the tests and here are the results. Also, I updated my signature line with my pool specs.
    Temp - 86
    TC - looks a little greater than 5 ppm but the test didn't go any higher.
    PH - 7.6
    CYA - 80 ppm
    ALK - 120 ppm
    Hardness - 700
    Doesn't that all look pretty good other than the chlorine and the hardness?
    Honestly, I need to get a picture of the "algae". I had a pool guy look at it and he couldn't tell what it was.
    I went to my local pool store and followed his directions. I shocked it two weeks ago with bioguard 3 and immediately followed with bioguard banish. I brushed before and after for several days. After a week I cleaned my filter cartridges. I saw no results other than foam on the top of my pool the next day.
    Then I was able to go to Leslie's (after reading the forum, I wish I hadn't) and was told to use their Black Algae killer. I added it per the bottles instructions on Thursday last week and brushed. I waited to wash my filter cartridges. Again I saw no difference. The pool foamed again and a green gunk stuck on the water line around the pool. I'm still struggling to get that all cleaned off.
    Lastly, my husband got into the pool with a chlorine puck and scrubbed each spot but I still see no difference. And, it's not spreading quickly either. It has stopped where it is so maybe thats progress. Or maybe it's just a stinkin stain and I cant tell (insert hair pulling emoji here)
    Thank you for your time - I really appreciate it!
    25K gal 17'x40' freeform gunite pool with spa built Nov 2013. Paramount in floor cleaning system, paramount clear 03 system, Jandy cartridge filter
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Sounds like a beautiful pool! Yes, your numbers look good for now. One question you didn't answer is what do you usually use in your pool?
    Don't put anything in your pool right now but chlorine in the form of bleach. If you the label of regular bleach and the Pool Essentials chlorinating liquid in the pool isle at Walmart, they are the exact same substance. Don't get rid mof the tablets, they will be useful, they have chlorine, cya and calcium. You don't need any more cya or calcium.
    A good rule is to only put in your pool what it needs. Read up on the BBB method here and at Pool solutions, I can't explain it as well as Ben and the other mods did back when this forum was in its prime.
    Then first thing to do is to get your chlorine up to shock level. If your test kit is still yellowish and not orange, we can add some bleach safely. According to the best guess chart, your shock level is 20+ppm. 1 bottle of bleach at 8.25% will add approx. 4 ppm FC to the pool, the Pool Essentials chlorine will add a little over 5 ppm.I feel comfortable adding at least 2 bottles, that should get us close to 20 ppm.
    After that, brush your pool every day, vacuum and backwash as needed. Other than that, we'll have to wait for your new test kit and see how it goes. Let Mme know!
    Jul 2013
    Oklahoma
    I have been using the 3" chlorine tabs from Leslie's.
    I am out of town until this evening. I will add the bleach when I get home. Which, after reading this forum is better anyway. Are the metal brushes better? I'm terrified they may be to abrasive?
    When should I retest?
    May 2014
    Retest every day, though accuracy of chlorine testing will not be good until you get the taylor kit. Many pool problems are the result of not testing everyday, and inaccurate testing using strips or the pool store. I am sorry, I just noticed the size of your pool was 25K (thought I read 20K earlier), so would add 3 bottles of bleach.
    I am not familiar with gunite pools, so maybe someone else can chime in with what kind of brush to use.
    Just to clarify, you will need to use a chlorine source in the future that has calcium in it, you just don't need the stabilizer in the pucks right now. Again, someone familiar with gunite pools can add to this.
    Jul 2013
    Oklahoma
    Ok, I just got home and it's raining but I am heading out to pour in the bleach and remove the chlorine tabs. I will keep testing and update you! Also, since it appears its just you and I in this thread, I may post under algae and ask about the brush.
    Jul 2013
    Northern Illinois
    Test for black algae in this manner and report back:
    Do the fingernail test to verify that you've got black algae. Scarpe some of the algae so that it gets under your fingernail and then smear the collected stuff onto thick white paper. An index card will do. If it's black algae, it will be dark green. If not green, you have something else going on.
    Jul 2013
    Northern Illinois
    How is your pool doing?
