Re: Can't Lower Cl Level
Swimdaddy has a great point which has not been brought up elsewhere for you. Your CYA may well lower in Spring, and with a plaster surface, the high FC is most likely not going to hurt as it will eventually come down.
Everyone has asked you about whether you use pucks or granular shock and I haven't seen your response. Both of those will raise/maintain CL (FC) levels.
