Re: Trouble Keeping Chlorine Levels Up
Try taking a cup of pool water and a cup of tap water and mix it well. Then use 7 ml of that mixture for your CYA test. Then multiply the result by 2. That will give you a rough measure of your CYA. If it is still near 100, try 2 parts tap to 1 part pool water and multiply by 3. Let us know.
